Melinda
First time making the spiral weave
8 posts in this topic
I recently made a sprial chain braclet for the first time this morning I think it come out good, I used 20g 3/8" green Aluminum rings.
I was wodering if there is a way that I can use bigger rings if that would help the weave keep it shape better. Is there any ring size that works best with this type of weave...if some can help me out with this it will be greatly appreciated.
Cheers
Edited by Melinda
Spiral usualy will unwrap it self more with larger AR rings.
Usualy people sugest a variant of spiral such as dubble spiral or inverted spiral its a lot more stable to necklaces or bracelets though its a bit larger.
Edited by losthelm
thank you so much for your help :) I will try the Double spiral and the inverted spiral weave to see which one I like better. The inverted spiral looks confusing but I think I can figure it out.
Edited by Melinda
You could also make it a continuous chain. No need to twist it before clasping. Make sure a necklace is large enough to slip over the head, but for a bracelet I would lean more toward a custom sizing to make sure it barely fits over the customer's hand. I would also use either a very strong metal or keep to the smaller end of the AR for this just so it can withstand the strain of being put on. You don't want it so loose that it falls off when you move your hand, but not so tight that you can't get it on/off. Then again, the only spiral weave I make is JPL. No need to twist anything there... :)
I'm curious about this one:
http://www.mailleart...pic.php?t=16611
To repeat the question I just posted there... is that a basic spiral weave that's been "locked" in place by just adding more rings? Or am I missing something?
Sort of. It is spiral weave with an extra row of fringe rings that cause the weave to hang in a spiral fashion but it wouldn't sit as evenly as a bracelet. It would look more like a strand of shaggy loops.
A properly locked regular strand of spiral would show off the feature better.
