Moondrake
Cleaning Rings
I just got my first order of TRL rings this week. After opening them all and starting to use the saw cut bright aluminum, I noticed they were quite dirty. My question is how/what is the easiest way to clean them? What do you put them in to clean/dry? Do you use/what kind of soap? Just water? Thanks is advance!
There are many posts on this subject, but the most common method is tumbling for a few hours with a little blue dawn dishwashing liquid and water in a rotary tumbler, or dry walnut shell in a vibratory tumbler.
my "poor boy tumbler" consisted of an empty peanut butter jar left in my car trunk for a couple of weeks. Or kids shaking it while in timeout.
I rather like this idea and may have to use it.
LOL! Great idea! My kid just brought home straight A's. He won't be on time out for a while!
for just cleaning the cutting lube, I usually just toss the loose rings in a jar, add water and dawn, shake for about 30 seconds and rinse. it doesnt shine them up like tumbling, but it gets rid of the crud
This is what I was looking for. Thanks!!
Edited by Moondrake
If you are looking to remove dirt from the rings a quick trip through soapy water will remove the oil and dirt. Aluminum will also put out a bunch of oxide that will turn your fingers dirty. To take that off you need to use a tumbler.
A good tip for getting your rings out of the jar or tumbler is nylons, that is what we use if we are just doing a quick cleaning on rings to get the cutting oil off.
Good idea. Thank you!
Hmmmmmm, I may have to look into a tumbler. Thanks
Edited by Moondrake
My usualy way is tumble with soap, then dump into a kitchen strainer and rinse them off nicely with lots of water.
Since you don't own a tumbler, just go for a jar and warm soapy water, then dump into a strainer.
I'd advise getting a new strainer specifically for this purpose. ;)
Most dollar stores carry them.
Shiz
Shiz
This is what I had done. Thanks for your input!!
