Best care for copper
#1
Posted 05 March 2012 - 11:55 AM
I read that furniture polish works wonders, and if done right, clear nail polish. So please tell me what you all think about it.
Thanks,
DBM
#2
Posted 05 March 2012 - 02:26 PM
My mother always used Brasso on the copper in our house when I was growing up, but i have a bird and don't like to use harsh chemicals. I recently cleaned a very dirty oven with just baking soda and water and no elbow grease at all.
Edited to add: Clear nail polish will flake off starting where rings rub against each other. Furniture polish will leave residue on the wearer's skin or clothes and can cause some nasty allergic reactions.
The gauge and hardness of the wire will determine whether it is suitable for use in jewelry. (Others will have to comment on this subject because it's outside my knowledge base.)
Edited by Brimley's Mom, 05 March 2012 - 02:29 PM.
#3
Posted 05 March 2012 - 05:22 PM
I think I can also grab about four pounds of electrical wire that can be reused as well.
Over 90% of my aluminium and glass has been reused from scrap welding wire that has been cleaned, and I was thinking of expanding that.
Also, I have next to no idea how to tell gauge and hardness using the codes used in Chainmail (There is a site I use that has the stats for when I am finally ready to buy some from The Ring Lord).
Thanks
DBM
#4
Posted 05 March 2012 - 10:18 PM
To clean copper, for me the best is lemon juice. Easy to find, cheap and ecologic. Works pretty well.
I do not know if you can reuse electrical cable copper (I do not make my own rings, buy them at TRL) but it is true than copper fine are much more shiny than thick ones.
http://www.alianhor.com
#5
Posted 05 March 2012 - 10:20 PM
#6
Posted 05 March 2012 - 10:39 PM
#7
Posted 05 March 2012 - 10:46 PM
I've also heard that washing them right away helps them stay un-tarnished longer, but I don't know how true that is.
May be true. I wash mine with lemon approximately each three or four months, rest of the time they just take shower with me and they do not tarnish a lot. It may also depend on the type of skin and what else the ring are in contact with. Anyway washed every morning and evening copper stay nice quite a long time.
#8
Posted 06 March 2012 - 01:55 AM
The best polish/cleaner I've found for copper is actually my own skin/sweat(YUCK!), but I can take a tarnished bracelet (copper or bronze, anyway...I don't know about silver) and just wear it for a few days, and it'll clean up like new. Doesn't do anybody else any good but me, though...and I can't clean up earrings that way either, not enough skin contact, I imagine.
Another good eco friendly way to clean it, though it sounds a little weird, is with ketchup...just squeeze some on to the piece, work it into the tight spaces and let to soak for a while, then rinse with water. Works about as well or better than lemon juice..I imagine between the vinegar (acetic acid) and the tomatoes (citric and malic acid), it may even be more effective than just lemon juice (just citric acid), and it sticks in the little nooks and crannies while it works because its a paste. I like just lemon juice though, too...
#9
Posted 06 March 2012 - 06:27 AM
The larger Cable lines from the pole to your home are often copper clad aluminum that snape when you try coiling I have a freind that works in the busness.
#10
Posted 06 March 2012 - 09:33 AM
#11
Posted 06 March 2012 - 11:07 AM
Thank you all very much for your input.
DBM
#12
Posted 06 March 2012 - 11:10 AM
DBM
#13
Posted 06 March 2012 - 11:11 AM
#14
Posted 06 March 2012 - 11:12 AM
Coax is often thicker and stiffer than some electrical wire but you may find your rings bend out of shape if the aspect ratio is too high. Be very careful removing the insulation so you do not nick or damage the wire itself. Coax has two layers of insulation; the first is fairly simple to remove, the second is tougher. Wear cut resistant gloves or you will have an accident.
#15
Posted 06 March 2012 - 11:51 AM
- madd-vyking likes this
#16
Posted 06 March 2012 - 12:21 PM
If you use the lemon juice or vinegar method to clean your copper swish it around in a thin paste of baking soda and water then rinse well, this will neutralize the acid and help stop the pitting.
= a good bit of advice...
There is a tool made specifically for stripping/splitting wire/coax/romex called, I think, a 'cable slitter'...typically allows for adjustment of the cut depth...makes for much safer and faster wire stripping than just a razor knife, for instance. It may or may not be worth the investment depending on how much you are likely to use it.
#17
Posted 06 March 2012 - 12:28 PM
...but then again, it gives you a good excuse to craft a chainmaille glove...
#18
Posted 06 March 2012 - 01:07 PM
lol that was my first idea, making a chainmail glove!
#19
Posted 06 March 2012 - 01:58 PM
I have such a tool and it is very difficult to get the cutting depth exactly right and the blade dull very quickly. We don't use that tool any more because our processor handles the wire with the insulation still on it.There is a tool made specifically for stripping/splitting wire/coax/romex called, I think, a 'cable slitter'...typically allows for adjustment of the cut depth...makes for much safer and faster wire stripping than just a razor knife, for instance. It may or may not be worth the investment depending on how much you are likely to use it.
#20
Posted 06 March 2012 - 07:24 PM
