blackKat Report post Posted December 18, 2014 I have only made chainmail jewelry before and realized when prepping this project idea that I wasn't sure what g and what thick ness to use. Planning on mixing 4-1 and 6-1 as well as playing with other weaves for design but if you think one weave would be best for the base I would love suggestions because I don't want to finish and find that the bag isn't strong enough or is to heavy to use. I was thinking of AA but again I have only done jewelry before so other experiences are much appreciated. Thank you, Kat Share this post Link to post Share on other sites
Kittensoft_Chainmail Report post Posted December 18, 2014 For a laptop out of AA you're going to want to go with at least a 16 gauge wire, and probably nothing larger than 3/8" ID. With stainless you can probably get away with 18 gauge and 1/4" ID, but that will be quite a bit heavier than AA. Lining it can be another way to use a lighter wire/larger ring ID, but then you have the fun of figuring out how you want to attach it the liner to the shell of the bag. Sewing can work, but it can be a bit of a pain, and unless your rings are soldered, the threads can work out, requiring occasional repairs. The advantage of this is a cloth liner will keep any friction damage between the rings and the laptop case to a minimum. Just a couple of thoughts I hope are helpful. Share this post Link to post Share on other sites
blackKat Report post Posted December 21, 2014 Thanks I think I have an appropriate plan and I will definitely be adding a liner as the idea of walking around with my laptop grinding at the bag sounds awful. It will definitely be more durable thank my duct tape and zip-ties bag. Thanks again Kat Share this post Link to post Share on other sites
Kittensoft_Chainmail Report post Posted December 21, 2014 Glad to be of help. Share this post Link to post Share on other sites
sir_osis Report post Posted December 21, 2014 stainless steel, titanium, niobium. you want strong, those are your best choices Share this post Link to post Share on other sites
blackKat Report post Posted January 27, 2015 I ended up using the 16g 3/8th for my bag and it is almost done and can hold its weight I will put up pictures after I finish the flap and the trim but I wanted to say thanks because if I had gone with my instincts it wold not have looked this good. Share this post Link to post Share on other sites
