iridian
Anvil setup for riveted maille
Hello/Greetings!
After lurking in these forums for quite a while, I finally got around to making an account because I wanted to ask a question:
I have the basic pliers/boltcutters and the rest already in stock but I will be moving from butted chainmail to riveted and now I need some extra equipment :).
For making riveted chainmail, what would you recommend for me anvil-wise? (Europe)
(This is hobby- related so I don't need anything 'industy'-grade)
For what your doing a larger piece of steel with a flat surface should work.
If you know someone with a machine shop bar drops can often be hand cheap.
A few inches of axel will if you can cut them square.
Search jewelry supply places for bench blocks, you can get something as basic as a block of steel, or they make bench blocks that are embedded in rubber or on wood blocks for sound reduction.  If you want to make your own rivets there's a thing called a riveting anvil that has multiple holes to work with various gauges of wire.
http://www.ottofrei.com/Store/Anvils-Bench-Blocks/Hexagon-Riveting-Anvil-Made-In-USA.html
