crkjelstrom
Do I have to use 16ga 5/16" for large scales?
I see it is what is recommended, but I wondered if it is absolutely necessary. All I am making is a keychain 9 scales long (large scale). I already have a bunch of 18ga 1/4", and I was wondering if anybody knows if I can use those instead, or if I absolutely have to buy the 16ga 5/16".
Thanks!
Edited by crkjelstrom
You only need the exact ring size to do the "regular" scale pattern.  Scales can be attached with all kinds of ring sizes. If your 18ga 1/4" is aluminum , it might be too flimsy to hold well with the weight of the scales though.  You may want to double or triple your rings.
Keep in mind that the holes in the large scales are approx. 5/16" in diameter, which is why you normally use 5/16" - 16 gauge rings, and adjust your work accordingly.
