Les
Arbitrary Shape Array
Here is some recent work.  I'm just getting back into chainmaille after being away for 10 years.
The FP6-1 cross is rigid and opens at the center to a kind of weird shape which lends itself well to use in the Arbitrary Shape Array to the right.  It's been a goal of mine to create maille that can be designed in such a way that it can take any shape with as few limits as possible.  The rigid tightness of this weave is key to holding the shape of the array.
The rings are TRL SXAB12716 (Saw Cut Bright Aluminum 12 gauge 7/16" inside diameter).  originated the central connections, though it is quite likely they are nothing new (are they?).
Les
Edited by Les
Just wanted to clarify; the object on the right is a shape-holding array.  First weave an [x, y] array and then press it against the desired source object.  You'll end up with a copy of the source object.  It's like a profile tool in chainmail.
Les
