Revah's Scales
Orbital Byzantine Ring Size Help
So I am relatively new to chainmailling and have only been at it for a year, but I love the orbital/byzantine weave infusion. The only tutorials for it I can find online is a class for $60 and a pdf of it for $5 but I don't like the chunky rings they use.
I would just like to make two bracelets, the byzantine rings being 20g 1/8" and the larger bracelet being 16g 7/32". I just need help with what size of rings would be able to orbit these weaves well enough for proper movement. An example of what I'd like to do is attached.
Alright, hopefully you've found your answer in the last 4.5 months...
I presume you're talking the outer two weaves there - the center one is the easiest, as it's just a 3-ring mobius joining sections of byzantine weave.
I've done orbitals before - I find them a pain.  Usually you want the orbital to be a ring size larger than the rest of your weave.  It can be done with all the same size, but it puts a lot of strain on the orbital ring in my experience.
20 gauge 1/8" rings makes a nice byzantine - which would help make orbitals it they are at least 5/32".
Now, this doesn't count springback, which entirely depends on your material and temper - so you'll have to experiment a little with your materials.  I prefer bronze or silver, but when learning, anything will work, though copper might be too soft for a good orbital.
Edited by Galileo
