Stay tuned and I will update soon.
Chainmail Jump Ring Maker
#1
Posted 02 November 2007 - 12:27 PM
Shepherd's Moon Chainmail
#2
Posted 02 November 2007 - 12:48 PM
Well, since I am a Mechanical Engineer I am going to set off to make and design a fully automated, cheap, effective, jump ring maker. This machine will coil any gage and I.D., any materials, with possibly the exception of Titanium, Silver and Gold because they are precious metals, and have to be treated with care. And will also cut your rings and collect in the bundles of rings you want you want, supposed.
Make it affordable or sell a license to produce such a machine under your patent and I'd be very interested.
#3
Posted 02 November 2007 - 01:32 PM
#4
Posted 02 November 2007 - 01:47 PM
That would be neat, although what I really want is a mechanical way to close (or open) a bunch of rings
Well if we're off in Makebelieveland and talking about dream devices, I want that, and robotic arms that can be programmed.
Then, I will load a spool of wire onto a rack, feed the end in, come back to my computer, spec out ring counts and expansions in an app, click "print", and then listen merrily for a day or two to the brrrrrr-click-chunk-bvmm-bvmm-shunk, while a shirt gets made.
Then I will be happy. Not until then.
Remember the pervasive rule of 2/3. Cheap, Fast, Good. Pick 2. If you think you can pick all 3, the process will pick 2 for you.
You can make it cheap and fast, but it won't be good.
You can make it good and cheap, but it won't be fast.
You can make it fast and good, but it won't be cheap.
Any one of the three will bite you in the ass. To meet fast and good, you'll have to try harder and harder, and then blow way over budget. You'll manage to get it good and cheap, but it'll be slow as cheese. You'll make it cheap, and fast, and think all is going well, but then you'll find out "Jesus, this is working like garbage."
However, I delight in the challenge and the tinkering, so, full steam ahead.
How "cheap" are we talking? Cheap compared to, say, $150,000. Or, cheap as in, under $1000?
#5
Posted 02 November 2007 - 01:50 PM
#6
Posted 02 November 2007 - 03:01 PM
You get one of those, and try and strip it down to what's necessary, and see how cheap you can produce it.
Anything cheap enough to sell to the masses, is'nt going to put up to any kind of abuse....like making bunches of 16ga stainless jumprings.
#7
Posted 02 November 2007 - 05:19 PM
I would be very interested to know what you have done design-wise so far. How do you plan to feed and bend the wire? More importantly, how do you plan to cut it? What will you use as an arbor? How would one make adjustments to it? What would make this machine unsuitable for use on precious metals?
I heard something from a NASCAR driver that's perfect for this situation: Don't tell me what you're going to do; tell me what you did.
There is no magic; only "stuff". - Nakor the Blue Rider
#8
Posted 02 November 2007 - 05:55 PM
#9
Posted 02 November 2007 - 06:12 PM
http://www.abiusa.net/Manloop.wmv <-- Vid 1
http://www.abiusa.net/AutoLoop.wmv <-- Vid 2
They're auto-looping machines.
The process is similar to Ferdinand Ziegler's designs, (what TRL, Whittling & Davis, & others use):
http://www.theringlo.../Toy_video1.avi <-- TRL Ring weaver Tor, vid 1
http://www.theringlo.../Toy_video2.avi <-- TRL Ring weaver Tor, vid 2
... which weave E4-1 welded mesh (when not enjoying their hobby of breaking down), directly from wire on a spool, at over 3 rings per second.
Both are not coiling machines, as you can see. They trim a piece of linear wire to a specific size each time. However, both are necessitated by function; they need to insert wire through existing loops.
I think TRL uses only slightly mutated run-of-the-mill spring-making machines for all of their loose ring orders (which are coilers).
That help at all?
#10
Posted 02 November 2007 - 11:36 PM
from what I gather the machines that make springs work wonderfully for this...
Well hell.
#11
Posted 06 November 2007 - 03:51 AM
#12
Posted 01 March 2011 - 10:08 AM
Has anyone put any thought to this idea lately? I think I have a few, but would like to bounce the idea's around a bit. The primary idea I have would be more of an addition to the Ringinator, but would involve a bit more designing to get it right.
I am thinking of adding a troth extention to the feed side of the Ringinator. This will allow for support while feeding. Also, an upper troth with a slit down the middle for a ram. The ram is driven by a threaded rod. The ram only pushes on the part of the ring furthest from the blade (so the ram won't get cut as well). A motor with a speed control turns the threaded rod, pushing the coil into the blade (previously set at the correct RPM for the material).
With this, all that is needed is to lube the coil, set the speed control, and turn it on. I think this would work well for materials that take extra time to cut, such as steel. This will allow you to set the cutter, then move on to making another coil while it cuts. More production in the same amount of time.
"Politics: "Poli", a Latin word meaning man; and "tics" meaning "bloodsucking creatures"." - Robin Williams
#13
Posted 01 March 2011 - 12:24 PM
Yes, I know. I am reviving a long dead thread.
IMO, this actually seems to be the best addition (to what we already have) that I have heard in a very very long time. However, there are a few kinks I foresee. How long do you plan to make coils? I don't really think I want a 3 foot or longer permanent troth either on my bench or sticking out into the room. If we are talking 12 inch coils then maybe, but I think that defeats the purpose of making the process faster. Secondly, you would have to use a fail safe for when a saw blade looses a few teeth and no longer cuts right. If not, you risk damaging the coil guide, motor etc etc when the devise jams. Perhaps use a force feedback gauge or simple friction block that would slip before a certain force on the blade is achieved. I'm all for automation and this seems to be the simplest and most useful suggestion I have heard so far. There are other hurdles I can see to the design, but other than what I listed none seem unmanageable. Maybe draw up a sketch or two so we can see what you are thinking?
Maybe a mod can split this discussion into its own tread?
#14
Posted 01 March 2011 - 01:48 PM
Http://www.harlequinweave.com
#15
Posted 01 March 2011 - 02:27 PM
Revised after five minutes and a quick sketch:
Mind you this is a VERY quick sketch. You wouldn't want the wire feed to feed into the clamping device, and you wouldn't want the tube to roll the coils to do its business there either. and if you use a mandrell with a small slot, you should also be able to hold the wire while starting the device until there's enough for your clamping device to snag it. If both the clamping device and the rolling pin are coated in a tough teflon coating (something easily replaceable because friction will eventually wear them down, but hey, you're just replacing essentially a tube over a steel rod, or putting on new pads, it shouldn't be too expensive to figure out a cheap way of manufacturing them), you should be good. Clamps should be primarily for pressure against rotation, and able to apply extra pressure to the rings.....
Or you know what. Screw it. Even if you use a thin saw, if you are able to pre-notch the rings as they feed on to to coil JUUUUUST enough to allow something to snag them from a rotational aspect, say a 3 inch thin metal cleaving bar that is no thicker than the saw blade, maybe that can hold it im place... Though you might still get the "machine cut" look due to a notch.... Maybe... I dunno.
Edited by The Postindustrialist, 01 March 2011 - 02:57 PM.
